Floyd County Indiana LTR Frequencies
toddballew
toddballew
Floyd County Sheriff and New Albany Police shared the same 5 trunked freq with different talk id's, since the update at the end of last month I havent been able to hear them, ever now and then one will work with id but nothing for days. Can someone help me find the freq. for these departments with talk id's. I have a Uniden BCT8 Scanner
thank you
Todd
toddballew
toddballew
Floyd County LTR Frequencies
I have put those in and talk id's still doesnt work. wonder if they are correct or not?
FPO703
Planet Earth
What scanner are you using?
Is the Bank set tp LTR?
Are the individual channels set to LTR?
Do you have the frequencies programmed in to the proper channels?
toddballew
toddballew
Freq. Programmed in the proper channels can you explain? or is it like the site shows it skips channel 1 and puts the 1st channel in 2 slot? is that what you mean sir? If so I didnt do that
FPO703
Planet Earth
You have to plug the frequencies into the scanner exactly like they are shown on the DB entry. It's the same way with EDACS.
That's probably why you're not getting anything.
looking for floyd county codes
i'm looking for the floyd county code like fire and ems( yellow) can anyone hlp me?
DJ88
Brick Twp., New Jersey
Whatever bank you are programming this system into, you have to program the frequencies as follows: 860.4875 (2nd channel of the bank), 859.2375 (5th ch.), 858.4875 (10th ch.), 857.4875 ( 14th ch.), 855.9625 (18th ch.) Also, if your scanner has this feature you can put it on ID SEARCH and it will let you hear all active talk groups in the system, whether ot not you have programmed them in. When it's on ID SCAN it will only receive the tgs you have programmed in. You can check the manual and see if this feature is available.
