Using Freescan with the database here. Any tips for the Floyd system. I am right on top of it, sure I just need to check or uncheck a box. BCD996XT. Have WGAARS working pretty good..
In fact, I received it with digital-quality sound when the Floyd County Deputy was behind me calling out my tag for speeding.
Metrofire31
Atlanta/Smyrna
WQIT636
W4AMP - I loaded my 396XT right from the RR Database using Freescan (which I use exclusively). I've had no problems monitoring Floyd County DTRS when I've been within range of it. In fact, I received it with digital-quality sound when the Floyd County Deputy was behind me calling out my tag for speeding.
Metrofire31
Atlanta/Smyrna
WQIT636
Also has Edacs ID format as decimal, ID mode as ID search, delay time as 2, both analog and digital AGC checked, apco band plan is blank. All talk groups have audio as digital only, MP25 tab has apco mode as auto, threshold is 8, hold time 0, modulation auto, p25 wait time 0, site type as motp25/p25 standard. I am only 15 miles from most of the sites, so I have tried both with attenuator on and with attenuator off. Figured the multipathing might have something to do with it. Also have GPS unchecked, none hooked up. Control channel only is checked and subdued which I suppose goes with the site type.
....I received it with digital-quality sound.....
moderator you can kill the thread, found out what I needed. Thanks
