Formula 1 racing
w2xq
Burlington County, NJ
Admittedly more than a few years ago, in the 1990s we went to quite a few races on the island. (Our seats were in the hairpin.) There were one or two vendor booths, as you come off the bridge onto the island, with printed lists for sale.
Have you looked through the myriad of F1 websites to see who might be selling such lists?
Montreal is a fun city, and there are some really good restaurants in Old City. Have fun.
IdleMonitor
The Ottawa Valley - Eastern Ontario
What is the best way to program these?
I have a 436HP so by the looks of it probably as a NXDN one frequency system or as conventional network. Or just leave it simply as a conventional channel and not worry about talkgroups and radio ID's.
I've now added the MRTC Nexedge allocations for the 2022 Australian Grand Prix to the wiki page, and will add updates throughout the season as I get them.
racingfan360
What is the best way to program these? I have a 436HP so by the looks of it probably as a NXDN one frequency system or as conventional network. Or just leave it simply as a conventional channel and not worry about talkgroups and radio ID's.
I would definitely recommend program as NXDN One frequency, but only in order to get the benefit CallerID. Leave the RAN codes and UID/GID settings as search. The MRTC system uses CallerID and that really helps identify what channel is assigned to that frequency (eg will show TEAM 1, LN CAR, LN PITWALL etc). The frequencies can change from country to country, but often not by very much.
VE2XWA
Montreal, Quebec
Im pretty sure F1 team are using TETRA.
ind224
Indianapolis
377.3 fly over holding due to rain perhaps 330p est (local) and sounds like out of play time need to abort
racingfan360
Some interesting findings here for Montreal. Best way to decipher all this and what's what?
Hi, yes these correlate to my post from April and the continued updates made to the wiki page here: Formula 1 (F1) - The RadioReference Wiki on who uses what.
The Riedel 415-430Mhz freqs are TETRA.
The McLaren and MRTC freqs up to 470 MHz are MRTC supplied and Kenwood NXDN9600. For those listed as MRTC you can read as Williams F1 Team. As with most MRTC license applications, I might expect 2/3 of them to be used, and the other 1/3 as reserve/spares.
The Ferrari related freqs (Risi/ Ferrari of Ontario/Racing Radios etc) will be for Ferrari Challenge, I assume analogue or maybe DMR
Most of the others are media related, and roughyl up until 600Mhz will generally be analogue (but check out the license to confirm modulation type etc)
racingfan360
Most of the 470-800MHz freqs will be RF Mics used with TV/video cameras. Those frequencies dotted amongst them and listed as Riedel/McLaren/MRTC will be car-to-pits telemetry links. The 1.2-1.6GHz links are car-to-pits telemetry links. The 5-9GHz freqs are video relay links. The 9.4GHz freqeuency is usally a [marine] weather radar. The 285/301Mhz frequencies are F1MS Marshaling/Flagging systems.
IdleMonitor
I hope this is not too long of a post, but here goes. Here's what I've been able to find within the tafl so far just by using different search terms. Some hints also helped as well.
Search Terms
GPF1 2022 TAFL Search Results
GPF1 2022 - Ferrari TAFL Search Results
GPF1 2022 - Média TAFL Search Results
Grand Prix radio station — 99.1FM or 104.5FM — to hear the on-track broadcast.
What's going to be analog, digital (DMR/NXDN), what do I program as a conventional channel versus a 1 frequency trunk. What's worthwhile programming? I'm assuming all the TETRA stuff is a no go.
What's able to be heard on a 436HP?
Where to go from here?
AMP Visual TV
160.1850 25K0D7W TETRA
160.7400 25K0D7W TETRA
162.6000 11K0F3EJN FM or NFM - Number Of Identical Stations 26
165.1500 25K0F3EJN TETRA - Number Of Identical Stations 26
165.6300 25K0F3EJN TETRA - Number Of Identical Stations 26
468.250 NFM 11K0F3EJN FM or NFM
Formula One Management Ltd TAFL Search Results
406.1875 25K0D7W TETRA - Number Of Identical Stations 136
407.7875 12K5F3EJN FM or NFM
420.6000 25K0D7W TETRA
452.1000 12K5F3EJN FM or NFM
452.2000 12K5F3EJN FM or NFM
452.3500 12K5F3EJN FM or NFM
452.5250 12K5F3EJN FM or NFM
452.8000 12K5F3EJN FM or NFM - Number Of Identical Stations 136
452.9500 12K5F3EJN FM or NFM - Number Of Identical Stations 136
453.2250 12K5F3EJN FM or NFM - Number Of Identical Stations 136
453.3250 12K5F3EJN FM or NFM - Number Of Identical Stations 136
453.4500 12K5F3EJN FM or NFM - Number Of Identical Stations 136
453.5500 12K5F3EJN FM or NFM - Number Of Identical Stations 136
453.8000 12K5F3EJN FM or NFM - Number Of Identical Stations 136
453.9250 12K5F3EJN FM or NFM - Number Of Identical Stations 136
454.1000 12K5F3EJN FM or NFM - Number Of Identical Stations 136
454.2250 12K5F3EJN FM or NFM - Number Of Identical Stations 136
458.6250 12K5F3EJN FM or NFM
462.1000 12K5F3EJN FM or NFM
462.2000 12K5F3EJN FM or NFM
462.3500 12K5F3EJN FM or NFM
462.4625 12K5F3EJN FM or NFM - Number Of Identical Stations 136
462.4875 12K5F3EJN FM or NFM - Number Of Identical Stations 136
462.5250 12K5F3EJN FM or NFM
462.7750 25K0F3EJN TETRA
462.8000 12K5F3EJN FM or NFM
462.9500 12K5F3EJN FM or NFM
463.2250 12K5F3EJN FM or NFM
463.3250 12K5F3EJN FM or NFM
463.4500 12K5F3EJN FM or NFM
463.5500 12K5F3EJN FM or NFM
463.8000 12K5F3EJN FM or NFM
463.9250 12K5F3EJN FM or NFM
464.1000 12K5F3EJN FM or NFM
464.2250 12K5F3EJN FM or NFM
Riedel Communications GmbH & Co. KG TAFL Search Results
415.6750 25K0F3EJN TETRA
416.7250 25K0F3EJN TETRA
417.1500 25K0F3EJN TETRA
418.9500 25K0F3EJN TETRA
419.1250 25K0F3EJN TETRA
419.3000 25K0F3EJN TETRA
419.4750 25K0F3EJN TETRA
419.6500 25K0F3EJN TETRA
419.8250 25K0F3EJN TETRA
425.6750 25K0F3EJN TETRA - Number Of Identical Stations 1549
426.7250 25K0F3EJN TETRA - Number Of Identical Stations 1549
427.1500 25K0F3EJN TETRA - Number Of Identical Stations 1549
428.9500 25K0F3EJN TETRA - Number Of Identical Stations 1549
429.1250 25K0F3EJN TETRA - Number Of Identical Stations 1549
429.3000 25K0F3EJN TETRA - Number Of Identical Stations 1549
429.4750 25K0F3EJN TETRA - Number Of Identical Stations 1549
429.6500 25K0F3EJN TETRA - Number Of Identical Stations 1549
429.8250 25K0F3EJN TETRA - Number Of Identical Stations 1549
Ferrari of Ontario TAFL Search Results
460.6125 11K0F3EJN FM or NFM - GPF1 2022 - Ferrari - Number Of Identical Stations 20
461.0750 11K0F3EJN FM or NFM - GPF1 2022 - Ferrari - Number Of Identical Stations 20
462.1750 11K0F3EJN FM or NFM - GPF1 2022 - Ferrari - Number Of Identical Stations 20
462.8875 11K0F3EJN FM or NFM - GPF1 2022 - Ferrari - Number Of Identical Stations 20
466.3125 11K0F3EJN FM or NFM - GPF1 2022 - Ferrari - Number Of Identical Stations 20
Racing Radios Inc.
464.6250 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 30
464.7125 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 30
464.7500 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 30
469.6250 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 30
469.7250 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 30
469.7500 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 30
Riley Motorsports, LLC
456.3250 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 10
461.9625 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 10
Risi Competizione - Ferrari of Houston
457.1625 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 6
462.0625 11K0F3EJN FM or NFM GPF1 2022 - Ferrari - Number Of Identical Stations 6
MRTC Ltd TAFL Search Results
454.9500 11K0F3EJN FM or NFM - Number Of Identical Stations 100
455.7500 11K0F3EJN FM or NFM - Number Of Identical Stations 100
458.5875 11K0F3EJN FM or NFM - Number Of Identical Stations 100
458.6750 11K0F3EJN FM or NFM - Number Of Identical Stations 100
459.4500 11K0F3EJN FM or NFM - Number Of Identical Stations 100
459.7625 11K0F3EJN FM or NFM - Number Of Identical Stations 100
468.4250 11K0F3EJN FM or NFM
468.6375 11K0F3EJN FM or NFM
469.3750 11K0F3EJN FM or NFM
469.6375 11K0F3EJN FM or NFM
McLaren Racing Limited TAFL Search Results
446.4500 11K0F3EJN FM or NFM
446.9250 11K0F3EJN FM or NFM
451.5000 11K0F3EJN FM or NFM
452.7000 11K0F3EJN FM or NFM
455.2875 11K0F3EJN FM or NFM
457.4875 11K0F3EJN FM or NFM
RF WIRELESS SYSTEMS INC. TAFL Search Results
450.0000 11K0F3EJN FM or NFM
450.7375 11K0F3EJN FM or NFM
450.7750 11K0F3EJN FM or NFM
451.5250 11K0F3EJN FM or NFM
454.8750 11K0F3EJN FM or NFM
455.4375 11K0F3EJN FM or NFM
455.7750 11K0F3EJN FM or NFM
456.8750 11K0F3EJN FM or NFM
457.0375 11K0F3EJN FM or NFM
460.0125 11K0F3EJN FM or NFM
461.1250 11K0F3EJN FM or NFM
Sky Sports - TAFL Search Results
454.9875 20K0F3EJN FM wideband 25 kHz
455.3625 20K0F3EJN FM wideband 25 kHz
456.2500 11K0F3EJN FM or NFM
457.0875 11K0F3EJN FM or NFM
457.2250 11K0F3EJN FM or NFM
457.3875 11K0F3EJN FM or NFM
457.6000 11K0F3EJN FM or NFM
457.7125 11K0F3EJN FM or NFM
457.8375 11K0F3EJN FM or NFM
457.8875 11K0F3EJN FM or NFM
457.9500 11K0F3EJN FM or NFM
458.0000 11K0F3EJN FM or NFM
458.2750 11K0F3EJN FM or NFM
466.2500 11K0F3EJN FM or NFM
467.1250 11K0F3EJN FM or NFM
467.2500 11K0F3EJN FM or NFM
467.3625 11K0F3EJN FM or NFM
467.6500 11K0F3EJN FM or NFM - Number Of Identical Stations 74
467.7000 11K0F3EJN FM or NFM - Number Of Identical Stations 74
467.8125 11K0F3EJN FM or NFM - Number Of Identical Stations 74
467.9250 11K0F3EJN FM or NFM - Number Of Identical Stations 74
468.0000 11K0F3EJN FM or NFM - Number Of Identical Stations 74
468.0500 11K0F3EJN FM or NFM - Number Of Identical Stations 74
468.2750 11K0F3EJN FM or NFM - Number Of Identical Stations 74
