- Joined
- Oct 24, 2013
- Messages
- 681
It works on the other device i have like the G4 pagerChances are you're either on the outer fringes of the system's intended coverage area and/or only within range of one tower on the cell.
Ok thanksThe G4 & G5 are known to handle simulcast systems well as has been documented here on the forums
This is not a “try this and see if it helps” suggestion. If you have something other than this it is wrong and won’t work.Ive tried that before as well. No help
Ok ill do it. I was using what the default wasThis is not a “try this and see if it helps” suggestion. If you have something other than this it is wrong and won’t work.
Didnt work. Is there anyone that look at my codeplug and see anything of whats wrong with it?This is not a “try this and see if it helps” suggestion. If you have something other than this it is wrong and won’t work.
I dont drivetake the radio for a drive near a tower ?
if it then works it is simulcast.
I tried being outside for an hour with it. No luckjust take it outside ?
and squelch on 2 ?
Squelch is on 2just take it outside ?
and squelch on 2 ?
853.1625 853.5250 853.6125 853.6375 |
Ok will do. Ill try it.Try deleting all of the frequencies in the site except for the 4 control channel capable frequencies. The scanner can find the control channel easier if it doesn't need to search through all of the voice frequencies.
853.1625
853.5250
853.6125
853.6375
OkIn the scanner menu, under Settings, you can also set the P25 Threshold. Change it from Auto to each of the manual settings to see if it improves decoding.
Did that just now and the error has dashes. Says 6 manOn the BCD325P2, you can press the volume knob followed by FUNC followed by the volume knob again to access the digital decode error rate on the scanner display to determine which manual setting gives the best decode. Pick a busy talkgroup and hold on the same talkgroup for all of the digital decode tests.
So now it's simulcast issue. But the other vhf p25 conventional channel is 154.875 that i have a problem rx'ing is error rate is between 50-110.On the BCD325P2, you can press the volume knob followed by FUNC followed by the volume knob again to access the digital decode error rate on the scanner display to determine which manual setting gives the best decode. Pick a busy talkgroup and hold on the same talkgroup for all of the digital decode tests.
You are still having a problem decoding the control channel on the trunked system. Run through all of the manual settings for the threshold and see if you can get an error value. You want to be as near to zero as possible. You are having the typical symptoms of simulcast distortion.So now it's simulcast issue. But the other vhf p25 conventional channel is 154.875 that i have a problem rx'ing is error rate is between 50-110.
