Fort Lauderdale P25
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
Rick225dm
Fl
Yes i have all of broward from sentinel in the sds200 I was trying to scan the 700 freq to find more channels it wont let me any info would be
greatly appreciated
Rick225dm
Fl
I was checking the antenna forums I wonder if a better antenna than the stock one would make a difference on the uniden
Gmork
Broward County, FL
Are you trying to specifically monitor this system & anything else? What area are you located? Realistically if you are in the city or close the stock antenna is just fine.
Rick225dm
Fl
I am just trying to monitor Margate Coral Springs in Coconut Creek I’m in Margate
N4DES
Retired 0598 Czar ÆS Ø
South FL
The Fort Lauderdale system is highly directional into the city and has to reduce its ERP to the northwest and southeast due to adjacent frequencies used by other agencies. YYMV when 3 or more miles away from the city limits using a portable scanner with a standard antenna, especially indoors.
Margate is on the county system and Coral Springs has a healthy footprint into Margate, so you should have no issues listening to either.
Gmork
Broward County, FL
What this guy said. Because he knows what he's talking about.
emscapt9816
Retired, but somehow working harder now...
Coconut Creek, FL
Be sure to enter the Coral Springs/Plantation/Fort Lauderdale as 3 separate systems. The RR database has it listed as one system. I've had great success listening to all 3 at home and on the road.
Rick225dm
Fl
Thank you guys for the info I appreciate it I deleted alligator alley it seems to speed the scan rate up this sds scanner is light years ahead of my
old radio shack scanner
tvengr
Well Known Member
Baltimore County, MD
greatly appreciated
If you want to scan all of the talkgroups on the Broward County system, while scanning, press the scroll knob and then E to switch to ID Search. Do the same to return to ID Scan. I would suggest trying the Wide Invert filter on the Broward County sites. I have often had good results using that filter on 700 MHz frequencies.
