I don't know if it's in any of Bill's books, but a cool mod would be to use the switch voltage that goes between 0v and 8v in the PLL circuit that are used for the 1000-1300Mhz range, that probably no one uses, and have that trigger a flip-flop IC and its two outputs goes to those two piggybacked memory IC's chip enable. Then you program a 1300Mhz frequency to channel 400 in both banks and it will toggle between the two memory banks and make a 800ch scanner. Add a LED or two to the flip flop output to indicate which bank that are in use.
Instead of the flip flop you can use a decimal counter IC and control even more piggy backed memory IC's. Wire a switch to the inhibit pin of the flip flop or counter IC to stop the bank switching if only one bank are needed for the moment.
/Ubbe
