Do you have the Global Attenuator on? It's located in ProScan General Settings tab.
Like in doctordialtone post#4.
Okay, thank you for this -- Yes, I was unable to figure out how to turn it off.
I've got it off now, let me try some things and utilize the post above's database
Give this file a try. Simulcast site is on system quick key 1. Brunswick site is on system quick key 2. It includes the Frederick Co sheriff. Turn off group quick key 0 to disable that. Open the file with ProScan and upload to your scanner.
If making changes in the scanner then you want to download the database and config to ProScan so things will appear in sync.
Likewise if you make changes to the ProScan database and config, you want to upload to the scanner so everything will be in sync.
Also, @ProScan when its plugged into my computer, it connects, and can see it on the virtual controller thing (or whatever) but no audio comes through at all. However, when plugging it in a regular power port, it works fine now.
Is it a whole different ball game to be able to hook it up and hear it through my computer speakers/headset?
Do you have an audio cable hooked up from the scanner to the computer?
To hear audio out of the computer speakers, here are the very basic steps.
1. Go to the Audio Control tab.
2. Select either Recorder, Source Client, Web Server, or RSOIP. You don't actually need to use any of those services.
3. Select the Input Sound Device.
4. Go to the Monitor & Test tab under the Audio Control tab.
5. Select the same audio service in step 2.
6. Check the Loopback box.
You're welcome.Ah, my apologies, didn't realize you had to have an audio cable as well. Thought the USB would do it all.
Thank you
So, is it working now? Don't keep us in suspense!
