W2JMZ
- Joined
- Oct 13, 2015
- Messages
- 59
I have the Yaesu ft-857d vhf/uhf/HF transceiver. Recently I added a mfj-969 antenna tuner and a 20m end fed half wave dipole.
So the issue I'm having (one of several now) is that occasionally when I try and transmit on HF, the fast tuning feature (little running man on the display) will turn on and sometimes off without me doing so either by the button in the mic or via the power button secondary function.
I thought it maybe the extension cable and coupler for remoter mounting I was using to give myself more wiggle room when using the mic. So I unhooked it and fed the mic cable back directly into the radio. This didn't seem to have an effect on it.
It doesn't happen every time either and I haven't noticed anything in particular that maybe causing this.
Any suggestions, there is nothing in the manual that would led to suggest what this could mean or be caused by.
