RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 7,402
I have an FT900 that has been in my closet for many years. It is like new condition, but now apparently not working.
What I have done is the usual CPU reset, both soft and hard.
But I don't think there is a CPU or VCO problem. The radio seems to operate normally from all the controls and display.
What it does not do is transmit or receive. If I operate TX in 10M FM, there is some small amount of carrier and in RX there is FM noise in the speaker. But not a lot of FM noise. Other modes have no sound or apparent RF power. I am thinking the problem is in the IF section of the RF board. I am suspecting the minus 9V inverter. Unfortunately there is no easy point to measure the voltage of this circuit other than inside the can on the exposed lead of the diode and one resistor. The chip iR3M03n2 is on the underside of the board.
I would do more poking but the service manual I downloaded is low resolution.
Has anyone fought this battle before? Thoughts?
Thanks Joe K4SAT
Thanks Joe K4SAT
