A couple random questions...
kslager
I recently put together and am testing a 4th pi 4 running the Broadcastify image. I chose a 8GB board since this system has a 4 Mhz spread (2 RTL's). Seems to be working pretty good. There really isnt a lot of traffic on it - rural midwest.
I know I can run multiple 'systems' (nodes) on trunk recorder, but is this allowed for Calls? (I thought I read something somewhere one time, but I dont see it now) I figured I would have to apply for the two sites, but do they mind if I run two sites on one pi?
Also, API Key's - I have no clue what they actually are: I have 3 other pi's at my house running 3 nodes, but I have 3 different API keys for each pi / node. I see where when you apply to ingest a new node, it ask to choose API key or provision new. When are you allowed to use an existing API key - same internet connection, same ingesting device, or same nodes?
I would like to bring that 4th pi on soon, just curious if I can run two systems/nodes, and when exactly one would need a new API key.
Thank you.
Deziel0495
PEI/NB Database Guy
PEI
Yes, you can provide as many nodes as your computer system can handle, just make sure each site has its own node.
Streaming multiple sites into 1 node is not the way the system was designed to handle the traffic.
All your nodes can use the same API, it doesn't matter.
