KD7RJC
- Joined
- Jun 22, 2023
- Messages
- 101
This was my experience installing a Yaesu FTM-500DR into a 2015 Jeep Renegade Trailhawk.
The single most difficult part was figuring out where to put the control head. I didn't want to go with a cupholder mount, the overhead console wasn't as suited as it was in my 2015 Frontier, and I wanted it to look as close to fac'try as possible.
I settled on the mostly empty switch panel below the radio. This switch panel on this particular Renegade has only the hazard switch in it, the other eight positions are unpopulated. Since the hazard switch is important this meant relocating the hazard switch function up to a new button installed up between the center HVAC ducts, and since the switch is just a momentary telling the computer to turn on the hazards there weren't any OEM-type hazard switches that would do the job. I did find such a switch on Amazon, one of those kits with a bunch of possible labels to use.
This is the switch panel as it started:
The cable connector uses yellow for 12V power to the light on the models that don't have heated seats, green with red stripe for the sense-wire for the switch, and black with violet stripe for the ground for both the light and the switch:
The switch panel itself pulled apart:
The dash without the switch panel along with the alignment of the switch panel individual switch positions:
And with a clone of the YSK-7800 head separation mounting plate:
...to be continued...
