G1 Battery Life
KC1ART
Yarmouth, ME
Does anyone have any data on the battery life in various situations on the G1? I know it’s highly dependent on how you’ve got it set up, but just trying to get a general idea.
I’ve got mine set up with the screen turning off, Bluetooth off, LED timeout set to only 8 seconds. No MDC decode.
Yesterday I was doing a priority scan of 5 frequencies with a look-back to the priority channel of 1 sec and the battery was dead in 3 hours which might be normal, but hugely disappointing.
w2lie
New York DB Admin
Long Island, NY
This is very short battery life. Are you using 1000mAh batteries? How old are the batteries?
KC1ART
Yarmouth, ME
Yes, they are the 1000mah batteries that came with the pager. And it’s brand new from Unication 3 weeks ago.
KC1ART
Yarmouth, ME
Maybe I’m a moron....I’ve been leaving it in the charging cradle as I play with different programming configurations and figured it was getting fully charged over night. Maybe it’s not? Gonna put it in the proper charging cradle and see if that’s the problem.
w2lie
New York DB Admin
Long Island, NY
You mean you are leaving it in the programming cradle? The batteries will not charge all the way in the programming kit.
What you might want to do is pull the batteries from the unit and charge them independently in the G1 charger in the aux. battery location. This will bring each one up to full capacity. Then put the batteries in the G1, use it as normal, and then charge as normal.
sibbley
Nazareth, Pennsylvania
I use the white eneloops from Amazon. I charge them in an external charger. I get 48 hours out of them in my G1. I haven't used the G1 charger in years. Best I could ever get using that was about 24 hours. If things are busy, ie, many calls, it may cut down battery life to around 36 - 40 hours. I use either a Lacrosse or Opus charger.
buddrousa
I get 48 hours out of my G1 for 6 months then it drops off a couple hours a week until I put new batteries in the G1.
Unication states you need to swap the batteries every 6 months.
G1 Voice Pager:
Replace G1 Batteries Every 6 Months
For optimal performance G1 Batteries should be replaced every 6 months.
Recommended Battery
Unication strongly recommends using Tenergy Premium 1000 mAh NiMH or PowerEx 1000 mAh NiMH rechargeable batteries.
G1 Programming & Battery Life
Contact your dealer for additional programming tips to extend your battery life and performance.
Batteries & Cold Weather
As with any battery operated device, freezing temperatures of 30 degrees & below may impact the G1’s battery life. The following preventative measures are recommended to maximum battery performance in cold temperatures.
  • Ensure that batteries are fully charged prior to any extended exposure to freezing temperatures. Do not leave your G1 in exposed temperatures for long periods of time. It is recommended to keep on your person as body warmth helps to protect from cold conditions.
  • Replacing your G1 batteries every 6 months is strongly recommended. Replacing your G1 batteries before the start of the cold season will help to maximize battery life. For optimal performance, Unication recommends using at least 1000 mAh NiMH rechargeable batteries.
*Please be advised that over tightening the battery door screws may cause the unit to not charge/program correctly. If unit does not sit securely in the cradle, please check the screws and loosen as needed.
KC1ART
Yarmouth, ME
Yep, that was my problem. The programming cradle *does* charge the pager, and I guess I figured my phone charges fully when plugged into my computer’s USB, why would the pager be any different. Turns out it’s *very* different.
Charged for a full 3 hours (till I got a green light) in the proper charging cradle. Going on 12 hours of priority scanning the same 6 frequencies from before and the battery indicator still shows full.
