IC-R15 - First Impressions
JeffFRANCE
Do you know what size of micro sd the ic r15 accept ? What is your advice to have confortable and performance ? Size, class, ???
The micro sd card is not supplied by Icom I would like to order a good one before to receive my receiver.... What is your advice ?
bearcatrp
Land of 10,000 taxes
The manual states 32GB. I put in a 64GB and it recognizes it and formats correctly. Haven't recorded on it yet to test it out though.
bearcatrp
Just tried using my CS software on the R15. Won't recognize the card. I pulled the sd card out and put in in my computer. Can't get past the com port. Will hook up the radio next to see if I have any luck.
JeffFRANCE
I have bought a micro sd sandisk 32go l
For the software I have planned to use Butel cheaper than Icom more efficient and strong support with updates....
KeeperOTAN
Havirov
After a week of using Icom alongside Uniden 125 XLT for the airband I am also impressed, despite the fact that it has one major and few minors flaws for me.
Short
Pros - 2 receivers, speed, sensitivity, bluetooth, recording, built-in attenuator, VSC, ANL, nice sound from speaker
Cons - mono jack, not all bluetooth headphones work even those with BT 5.2 and HFP 1.8, sensitivity, only 3 group links for scanning
Long
Major flaw Mono 3.5mm jack! Damn, I want stereo sound without adapters sticking out of the device. Mono-stereo 90° adapters are not available in Europe and China, but they are available in the US. The problem with adapters from the US is their shape, because the jack on the ICOM is very recessed, so the jack on the adapter does not fit along its entire length and price for little plastic adapter.
Minor problem is Bluetooth headphones. Even though I have Sony headphones that meet the BT specification, the sound from them mutes and distorts when signal drops just a little bit to the point where chatter is unintelligible. Maybe it's a problem with the BT module in the Icom, maybe it's bad headphones.
Scanning speed – compared to the Uniden 125 XLTC, it's in a completely different league. Thanks to two receivers and the ability to scan on both at the same time, the scanning speed is incredible. When I compare it to scanning with Freqman plugin-1ms detect time in SDR Sharp (Airspy Mini), ICOM scans stored channels just as fast, or even slightly faster!(Not to be confused with the Frequency Scanner
plugin, which scans at "warp speed")
Sensitivity! I didn't believed I would be able to pick up ATIS from our local airport 25 km away in undulating terrain and in the middle of the city! Normal air traffic at FL360 can be picked up at more than 300km with small FA-B02AR airband antenna. It even receives PMRs and local repeaters with this narrow bandwidth antenna, Just WOW! Uniden was silent...
Sensitivity is also a problem, because the IC-R15 can be easily overwhelmed by RFI from the electric oven of a local kebab vendor when you walk by, and even from PC monitor at home, but compared to the competition in the form of the Uniden 125, we have a built-in attenuator that can handle receiver overload problems. Also tested on an unfiltered system without CCIR-DAB-LTE filters with a large airband dipole antenna. ATT OFF and squelch needed to be set to 2, and there was no problem with reception.
This feature is probably insignificant for US airband listeners, but important for European listeners. Unlike Uniden125, this scanner has a narrow filter for AM, so it can easily separate traffic on two adjacent channels with 8.33 kHz channel spacing without crosstalk and without jumping to the channel with a stronger signal.
I use RT systems for programming, and working with categories and banks is a joy! 2000 channels, I think that this can store almost all frequencies for European airspace. When scanning with the IC-R15, the only downside is that there are only 3 group links where you can set the banks that will be scanned. 6 or 10 groups would be ideal (if anyone from Icom is reading this, here's a tip for improvement for the next FW version).
Is the IC-R15 worth the high price? Yes and no, for some, it's just an expensive analog receiver with no DMR or other digital features, but for aviation band listeners and airshow photographers like me, it's a must-have. It's my second handheld scanner, and I should have bought it right away instead of the Uniden. For such fast scanning on two receivers, I would have had to buy two Unidens, which is more than two-thirds of the price of the IC-R15, and the rest of the price is easily offset by other features such as sensitivity of receiver, bluetooth, recording, attenuator, VSC, ANL, narrow AM filter :)
bearcatrp
Dedicated receivers have always been better than scanners. When I was scanning a mil base with the actual frequencies thats about 50 miles away, all my scanners would skip right by those frequencies I have on the R15. Even locked on to their tower, then set my 325P2 and my 160DN to scan mil air. Watched it scan right past the locked in frequency on the R15. Scanners are good for certain things but receivers, harder to program, do allot better! Just wish Icom would build a R30 replacement or more R30's.
JeffFRANCE
Dears all, ic r15 arrived this wednesday first tests are very very impressive performances in air band are crazy ,!!! All my receivers are far of this ic r15 !!!! Dv10, sds100, aor8200, yupiteru 7100, 160dn
I have the butel software and start to create bank, memories...
Do you know where I can find butel files for the IC R15 with marine, airshows, pmr frequencies...?
Thanks for your help
JeffFRANCE
The Yupiteru is equal with ic r15 for sensitivity but quality of the voice, screen, scan speed and size ic r15 is much better....30 years of différence but the Yupiteru is a VERY VERY GOOD receiver is a collector of 90 !!!
JeffFRANCE
Icom did it right on this receiver. Just disappointed no waterfall display like on the 52a.
You are right and when I see the involvement of Icom vs AOR to improve their radio.... I understand why AOR is the best !
I have the last receivers Sds100, DV10 and IC R15....
Dv10 is the best... I wait the new IC R30 to see... but without DMR and Tetra I ll never by it
For your information my best receiver is the 5700d and the 2nd the IC R8500
The best compromise is the 160dn.. for the price performance are very good
JeffFRANCE
Do you think that Icom is able to improve this ic r15 by firmware ? Like add waterfall, nxdn, descrambler, mask frequencies to secure when is used in public.....
This radio likes very good why they don t en large his capacités, functions, modes ??? With this way they use owners to help them and in the same they will be better for next receivers génération like Aor do !!!
What do you think if each owner send a mail to Icom to improve this ic r15 firmware ?
Can they be stimulated to do it ????
1 year without new firmware 🤔 no work on it !!!!
bearcatrp
I doubt Icom will do any firmware update to do this. they prefer to make a newer radio. I already sent Icom a message about AOR is stepping on there toes with the DV3 coming out and DV10 with more functionality. Would say everyone needs to send them a message. I commented about an upgraded R30 to take on AOR. With the big E going on in this country, didn't hink anymore P25 radios would come out. Uniden seems to hit one out of the park with the 150. The DV10 could be a good one but has its share of issues and the cost is nuts. Have always preferred receivers over scanners. Will be down to one scanner when my 160DN sells. Plan on keeping the 325P2 as it does fairly well.
JeffFRANCE
Hello everyone,
Question for IC R15 users: a category can be assigned to each frequency?
I know how to do it for a group (bank) but not for a channel (memory).
Either I haven't figured it out, or ICOM has made a major oversight.
For example: if I create a local Aviation bank, I know how to assign it an Aviation category with the airplane logo.
If this bank contains tower, ATI, approach, ground frequencies, etc., I don't know how to assign a category to them!
Weird! I must have missed something, lol.
Is it possible or not?
Thanks in advance and MERRY CHRISTMAS TO ALL!!!!
JeffFRANCE
I recheck a New Time this week end to find the solution....with Icom all is complex for basic tasks...
DudleyG
Lexington, Ky
Simple example.
Category ---> AIRPORTS
GROUP/BANK --- > 00:LEXAIR 119.100 TOWER
GROUP/BANK --- > 00:LEXAIR 120.150 APR/DEP (E)
GROUP/BANK --- > 00:LEXAIR 120.750 APR/DEP (W)
GROUP/BANK --- > 02:CINAIR 118.300 TOWER
GROUP/BANK --- > 02:CINAIR 123.875 APR NORTH
GROUP/BANK --- > 02:CINAIR 119.700 APR SOUTH
Category ---> TRAINS
GROUP/BANK --- > 01:LEXRR 160.515 NS DISPATCH
GROUP/BANK --- > 01:LEXRR 160.965 NS DISPATCH
GROUP/BANK --- > 01:LEXRR 160.845 RJ CORMAN
Category --- > ARTCC (Enroute Dispatch Centers)
GROUP/BANK --- > 03:INDY 126.375 WINCHESTER
GROUP/BANK --- > 03:INDY 123.773 LEX-DACOS
GROUP/BANK --- > 04:ATL 126.675 CHATTAGNOOGA
GROUP/BANK --- > 04:ATL 132.625 SUGARLOAF
00: is a group, LEXAIR is a BANK
01: is a group, LEXRR is a BANK
Basically, a CATEGORY is a collection of GROUPS with similar type of services.
LEXAIR is Lexington, KY Airport
CINAIR is Cincinnati Airport
LEXRR is railroads that run thru Lexington, KY
