G1 charging problen
cabelas16
So i ran my g1 completely dead, to the point ut shut off, i put it on the cradle charger, and it wouldnt charge. Blinked red on the dock. Is this a known issue with these pagers? The fix?
evfd1625
Indiana
Replace the batteries. Or take them out and try charging them in another charger and see if that fixes it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Sounds like the issue I had with my G5. Have you tried a battery pull?
10-75
New York
First I would check and make sure your contacts on the bottom of the pager and charger are both clean.... I have had the same issue and that was the cause most of the time.... If that doesn't help, I would replace your batteries.... I have never had so many batteries fail in any device I've ever owned. The batteries in my G1 over a short period of time all developed a high internal resistance and ended up not holding a charge or refusing to charge. I have to say the G1 is a great pager marred by poor battery design / capacity.... Good luck...
