G1 issue
btritch
I've had a Unication G1 for awhile now and not had any problems at all, I have a reception problem at night on the charger caused by some kind of interference in the bedroom so I ordered an amplified charging base for it. While it works great as far as reception goes I have a couple of issues that I'm not sure how to fix. First when I lock it into the charging dock like it's supposed to be I don't get any audio out of the speaker and I can just unsnap it from the locked position and it works fine however when it moves around it apparently stops charging. This is twice now it's been dead the next morning. The charging cradle is only a couple of weeks old. I bought it new in the box. Is there something I'm doing wrong causing this?
62Truck
Ordinary Subscriber
Ø
Your best course of action is to try and contact Unication. Their tech support is pretty good. IF you haven't done so already make sure the contacts on the bottom of the pager are clean. I have a G1 and amplified charger, I've owned both for almost a year now with now issues.
