G1 PPS - Unhandled exception error on programming pager
basssears2
We've never run into this before, anyone else?
Load G1 PPS (R03.07.03 - R02), load codeplug (reads file fine), when I click "Program Pager with Existing Codeplug File" I get an error as it tries to write:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object.
Details Continue Quit
Click "Continue" and it just freezes there (and never unlocks the COM port, have to disconnect and reconnect USB cable to get dock recognized again). Click "Quit" and, well, yeah, it's Quits.
Any ideas?
-- Bass
