G3 CTCSS help
druhe
Southwest Pa
I have programmed my G3 with an analog zone with a mix of channels being CSQ and CTCSS. The CTCSS is not functioning, the channels that have the CTCSS programmed are receiving in CSQ mode. Another issue while in scan, once landing on an active channel, the channel displays CSQ instead of the channel name.
Thanks in Advance
hazrat8990
Wyoming
How do you know the CTCSS isn't working? The only way to verify is if a radio with no tone (or the wrong one) will break squelch. Also, CSQ is displayed on the screen during receive since there's no radio ID info on the carrier frequency. Perhaps MDC-1200 protocol displays something different, but I don't have a way to check since everything here is P25.
druhe
Southwest Pa
Actually CTCSS is working correctly, the problem was in the test transmitter. The display is something I'll need to get use too.
Thanks for the reply
