G4 Antenna alternatives
bob550
Albany County, NY
I've attached 2 photos showing the cut I made on my KRA-32K antenna and the finished product mounted on my G5. I've been using this antenna consistently for over 4 years now and it's been performing very well.
brndnstffrd
CT
If you use these little gems, the likelihood of messing up the port will be drastically reduced. Also, if you have, or plan to get an SDS200, they work very well for preserving that port as well. I just wish they had a USB mini available. They are a tight fit when using the amplified charger, but if you rock it in, the pager will fully seat. You will need to remove the dust cover for the port, so don't be dropping it in any puddles afterwards.
Have been using those on my G5 for years now. They work great, allow charging and programming. I have them on several other radios that have USB charging and many of my other devices too. A nice benefit is that it streamlines the connectors so you can use the same cable for devices that have Micro or USB-C.
