G4 call issue
firebell9137
Hi. I have a G4 why does it cut off the beginning of the voice message/calls? Ive tried turning voice buffering on and off to no help. It's on the st louis SLATER system. It's a hi/lo tone. TIA
hazrat8990
Wyoming
Is it an older pager that has been "upgraded" to V2.02 firmware? If so, the firmware is most likely the culprit. What is the model number and which version of firmware are you running?
firebell9137
Is it an older pager that has been "upgraded" to V2.02 firmware? If so, the firmware is most likely the culprit. What is the model number and which version of firmware you're running?
V2.02
Model #: G4D66BE-SXXXENB702UNI
Hardware says: SAW Filter
