G4 call issue
firebell9137
Hi. I have a G4 why does it cut off the beginning of the voice message/calls? Ive tried turning voice buffering on and off to no help. It's on the st louis SLATER system. It's a hi/lo tone. TIA
hazrat8990
Wyoming
Is it an older pager that has been "upgraded" to V2.02 firmware? If so, the firmware is most likely the culprit. What is the model number and which version of firmware are you running?
firebell9137
Is it an older pager that has been "upgraded" to V2.02 firmware? If so, the firmware is most likely the culprit. What is the model number and which version of firmware you're running?
V2.02
Model #: G4D66BE-SXXXENB702UNI
Hardware says: SAW Filter
hazrat8990
Wyoming
The only way to fix your issue is to downgrade to V1.35
ciscovk
Same question, Hardware says: SAW Filter on V2.02 firmware, is it normal? On what does this affect? Before upgrade was vision 1.34
hazrat8990
Wyoming
Which question, the one on the first post, or post #5?
K9KLC
Southwest, IL
Where are you seeing this "saw Filter" on my info screen it just says firmware 2.02.
hazrat8990
Wyoming
That info shows up on the main screen in PPS and is only a reference to what type of chipset the pager was made with. Older ones like mine will show basic, later ones will be the SAW filter, and the newest are G5N.
If you click the button to create a new profile, you will see all of the different models available. There are many, so it is wise to let PPS read from device to avoid having a conflict by selecting the wrong one.
K9KLC
Southwest, IL
Ok thank you. My G5s are from 2019. Not sure about the G4. I think it's a little newer. I'll read them and double check. I'm not having problems at the moment with 2.02. ( that I can tell but now wondering about some of the calls being cut off). I had to upgrade them when I got them, the latest PPS wouldn't work with what they had on them.
Where is that on the PPS I can't find it ... also is it better to have it off or on? Everyone says different things.
K9KLC
Southwest, IL
thank you.
