sibbley
I'm have a bit of an issue with a talkgroup that is NOT programmed getting through during Normal Trunking Talkgroup Scan. It is an encrypted talkgroup, so you can imagine how annoying this can be.
I was reading about the wildcard 65535 and this made me wonder. The system I am listening to uses patched supergroups in the 65xxx area. If by chance, this particular 65535 supergroup is used, could that open the radio to receive talkgroups that are NOT programmed for normal talkgroup scan?
When this happens, and I start hearing the encrypted tgid, I can only reprogram the radio to get rid of the offending tgid.
Is there a way to set the G4 to not receive the patched supergroups? Or can the radio be set to mute encrypted transmissions.
