G4 relay
95gt302
Hi all, forgive me I'm new to all of this. I have a G4 with an amplified charger, that I have built a station alerting system for from stuff I had laying around. My issue is I guess two-fold, firstly I guess I don't fully understand our radio system I know it's P25ii and apparently simulcast on conventual ( I'll post a link to the wiki for the system for reference) so I'm probably doing something wrong, secondly, I had done some research and found that you need to program the relay to close which I have done. I have tried all sorts of things with negative results. I have turned the relay on in conventual and p25 together and separately and still get nothing. I know everything "downstream" of the charger is functional so it has to be something programing-wise I'm doing or not doing.
95gt302
As a follow up question to this. Is it possible that if the pager's knob is in the "wrong" position the relay won't close even if everything is programmed properly?
leroybrewington
Delmar, Delaware
Could be the amplified charger relay is bad. I had a county replace all their Minitor amplified chargers with Unication amplified chargers and G5 pagers. The charger relay outputs are connected THROUGH another 12VDC relay coil (with a protection diode) with a higher contact amperage rating to control the alarms, this keeps the current rating on the charger relay low. Within a couple weeks a few charger outputs had stopped working and the relays were stuck on. The current rating on the amplified charger is more than enough (400ma) to handle the 12VDC relay coil (150ma). The chargers were replaced and haven't had any problems since, my guess is the relays were weak from the start??
