G4 scanning screen
Volfirefighter
Canton, OH
On my G4 while scanning a P25 system only with no conventional frequencies, the screen while scanning and no traffic shows 3 lines:
Zone 1
Fire (Knob Alias)
RFSS/Site:2/63
Is there any way to change what info is displayed here? Also, is there any way to change what info is displayed when it stops on traffic? Currently, it shows Talkgroup Alias and Radio ID.
kruser
Well Known Member
W St Louis Cnty, MO
Start PPS and select to Edit a Profile. Chose your current profile.
Then look at the Home Screen Tab under tabs D7.
You can create a custom home screen there which will display while the G4 is not receiving any traffic.
I think some of the info may be static and always displayed like the RFSS/Site line for example but you can display several other lines of info when it is waiting for a voice call.
I've only slightly customized my G5 Home Screen so it shows more info but I think there are other items I can make it display.
When my G5 is receiving a voice call, the display shows pretty much what it sounds like you are seeing. I've never looked to see if that display screen can be changed so I'm no help with that one.
bob550
Albany County, NY
You can begin by naming your zones something more descriptive, unless "Zone #" better serves your purpose. Currently, there's no way set an alpha alias for radio ID's.
kruser
Well Known Member
W St Louis Cnty, MO
Yep, I do this also. It helps a lot when you have a lot of systems and zones.
