G5 audio out?
mdsxfire
EDBM
Uxbridge, north of the river Thames
Roger that. I was just thinking along the lines of when I get one if I wanted to start a stream how I could do it. Probably get a BT dongle for my pc and try that, or just get an amplified charger and six out, at least some options
k3sls
FM03qu North Myrtle Beach SC
cpetraglia
Fairfax, VA
Already tried tapping the audio out per the G1 diagram. All you get is a loud pop when a TG becomes active. I think you have to hit the signaling pin with who knows what. I suspect that shuts off the internal speaker and routes the audio to the base connector. With out knowing what that signal should be, I did not proceed any further. I want to keep my G4 for a while.
Mr_Boh
The Land of Pleasant Living
This is the bluetooth streaming adapter I have used before and I think it works well because it is one of the easier bluetooth devices I have paired. Also an agreeable $21 so even when you are done using it for audio out, would make a good wireless adapter for a home theater system or whatever else. They give you the audio cables in the box too.
https://www.amazon.com/Logitech-Blu...&sr=8-1&keywords=Logitech+bluetooth+streaming
k3sls
When I get my scope back from repair, I'll probe around see what's on the output and where the return is supposed to be. Even if it can be identified, there's still the issue of rigging up a connector.
IAmSixNine
Dallas, TX
Not sure if its still an issue, but the BT audio on the G4/G5 used to have a beep at the begining of every RX transmission. They had BT 2.0 so it was an issue for a lot of people. But its been a while since it has been discussed. So not sure if its still a problem or not.
cpetraglia
Fairfax, VA
I picked up an Amazon Basics BT 2.1 speaker. No beeps, noises whatsoever. I am still using R11N2 FW. The beeps are not coming from the pager, but from some of the different BT receivers people are trying.
