G5+ does not reference MDC call list
faojk911
Rhode Island
I just recently placed a G5+ into service (FW 2.03). Originally transferred an existing code plug from a G5 (FW 1.35) with same band split into the new G5+. Everything works fine, except my MDC protocol channels do not display the Caller ID as programmed in my group list. To explain, my 4 dispatch consoles are assigned MDCs 1001-1004 for our analog fire channels, and the same IDs for our police P25 conventional frequencies. When active on the fire channel, the decimal equivalent displays (my display settings are set for decimal private ID/system). It will not display the name associated in the call ID list. However, on the police P25 channels, it does display the name, Dispatch 1, Dispatch 2, etc. Seeing issues on the board here that importing a code plug sometimes causes issues, I did a factory reset of the G5+ and started with a clean file, manually entered all the programming, same results. I also exported the caller ID list into CSV format from the working G5 code plug, imported into the G5+ code plug, no change. Changed the pager settings to display HEX, again, fire MDC channels display the HEX code (1001, 1002) and does not pull the name from the call ID list. Police P25 channels still work appropriately, displaying the associated ID name. Curious if anyone has experience with the new G5+ models that utilize the Caller ID and experience the same, if worth kicking up to Unication as a bug. TIA.
