G5 menu info
Nascar18
Southeast Massachusetts
I was just wondering is there a way to see what is programmed in the G5 menu? If you were to forget what is on knob 6 zone 2 position.
pokey
When you’re monitoring the knob position that you want to see, press the Z/C button and then the details button. It’s all in there.
Nascar18
Thank you. That is great info. Is there a way to see what is loaded in the G5 without going to the knob position?
Another question when I update the profile the new info isn't programming into the G5 all the time. Like if I move a DMR system into a new zone it's not showing up in the G5.
BenScan
D/FW
Another question when I update the profile the new info isn't programming into the G5 all the time. Like if I move a DMR system into a new zone it's showing up in the G5.
Try writing a blank profile to it, and then writing the profile with all of your stuff. I find I have to do this with my files. I think it's mainly a problem with very full profiles.
BenScan
D/FW
Hi Ben,
I gave that a try now it won't program the main profile.
I reduced the zones and had a few duplicates.
Hmmm. Not sure what to tell you. FYI: you can also hold the joystick in the pointing down(not center) position, and eventually, it will display what's in a particular knob.
