G5 pager speaker replacement
sheintz
has anyone replaced a speaker in the g5 mine is sounding like garbage crackling and very scratchy. and where can you get a speaker i cant find any on unication.
blackbelter
Perhaps using an external BT speaker and or an amp charger will define the issue as the system or the G5 internal speaker..
K9KLC
Southwest, IL
I agree, I'd try something else prior to jumping right to a bad speaker. Sure they can fail but mine are from 2019 and still sound great. Just always good to double check.
sheintz
I know it’s the speaker on the pager in the amp base it’s ok and at low volume it sounds ok anything above 50% it’s sounds like crap. I can’t carry a Bluetooth speaker around out in the field for work lol
K9KLC
Southwest, IL
Sounds like you have certainly diagnosed the problem. As far as the speaker, I have not changed one and the furthest I had mine apart was to swap the battery out. Good luck, let us know how I works out. Other than trying to get a hold of a dealer and having them handle a return for you, I'm not sure what else to recommend here. Perhaps someone will chime in yet with an idea on repairing it yourself.
