G5 paging on 800
northwoodsradio
Question, so recently our tones are being patched from vhf to 800 and they work great to tone off on 800. Works flawless. I added the tones as a subgroup in the knob settings on the Fire Main in a trunking talkgroup normal scan. But when I did this, it blocks out that talkgroup from scan. How would I setup this so it would scan and transmit during scan instead of only when it tones off but still would tone as it captures the tones?
amys17
East Sparta, Ohio
In the sub group settings for that talkgroup, put a checkmark in the alternatives box. Alternatives means yes listen for tones like set up, but also allow all audio through on that talkgroup even if there isn't tones.
northwoodsradio
So I enabled it on the PPS under the Sub-Group setting for the alternative box checked, when I key up our portable that talkgroup still doesn't light up the transmission under Trunking TG-Scan. I have for the for the Binding Feature Sub-Group Feature Checked. Prior to adding this subgroup, pager was lighting up our Fire/EMS Main Talkgroup
