G5 Push to unmute/no audio on conventional analog
BlackSheepDue
Naples, ME
I will preface this with saying I know there are multiple threads on a similar topic and yes I have read through most but I am unable to find my actual situation. Most of the threads I have read are in reference to having to push to listen while monitoring trunking systems but I am having that issue on conventional QCII channels. My G5 has been working exactly as it should for the past few months until all of a sudden I noticed it didn't alert for a call. I have looked everywhere in my programming and the menu options on the pager with no luck. On selective call the pager does not alert unless I hold the push to listen button when the tones go out. On monitor I only get audio if I push to listen with one exception. If I switch my radio to talk around the pager unmutes when I key up but as soon as I go back to the repeater all I see is the signal bar but I get no audio. I have checked and my duty is set to on. I have reprogrammed the pager a few times, pulled the battery out, and reset to factory settings all to no avail. I will attach pictures from one of the channel settings but can provide more if needed. Apologies if this exact scenario has been covered but I don't think I changed anything to cause this and have been basically banging my head against the wall trying to figure it out.
hazrat8990
Wyoming
Try changing the reset mode from 'Auto Reset' to 'Delay N Reset' with something like 20 seconds. Also, shouldn't the paging channel be 'Selective Call'?? Not sure if that matters, but definitely try changing the reset mode and select priority at the bottom.
