You have to set the channels to record in the PPS.The g5 records when monitoring a specific channel but is there way to have to record when it is scanning multiple channels? Can't seem to figure that out..
Under which Letter/Number? I don't see it in frequency settings (D2) and I can in D5 when in monitor mode, I can select voice storage (all). When in D5 and in any "scan" mode, the only settings in voice storage are off and ID match. I'm getting stuck at this point, ID match is selected but I guess I don't have the ID matched.
Is there any way to turn off the annoying beep at the end of a transmission when playing back audio? Also it's cutting off the end of the transmission on playback.
I can't possibly be the only one with this issue. Trying to listen the the recordings is useless.
I too am having difficulty setting up the voice recording of a conventional channel, as D4 appears to be only for trunked talk groups. Does anyone have this figured out?
There is a setting in the PPS to change the notification tone volume.
If I have alert tone set to silent, I still get that annoying tone at the beginning of each recording, but not the actual transmission....
I have several G4 units and yes they do get cut off at the end of recordings.
I turned the alert volume down so when my play back happens the beep tone is barely audible.
