Some help on inputting data ?
ProScan
Software Provider
Ontario, Calif.
And what is UID recording vs regular recording i tried searching it but can't really understand what it means
The Recorder is based on TGIDs and conventional frequencies which is used for matching and appending existing recordings. The UID Recorder is based on UIDs.
RMason
Mississippi / Colorado
So what should i change to fix this?
I have the same freqs with 3 different tones one analog one nxdn and one dmr but it's stopping on the nxdn and showing dmr . like in the video i sent it's stopping on that channel and sometimes i hear data sometimes i hear nothing and it's hung on that freqs and showing dmr.
It looks like you have 155.7000 programmed 3 times - right?
  • Analog - Dickenson / Dickenson County - Clintwood / Police
  • NXDN - Dickenson / Dickenson County / Sheriff Dispatch (Cintwood)
  • DMR - Dickenson DMR / Dickenson DMR / Town of Clintwood
You did not include the Dickenson County - Clintwood group in your programming screenshots. I suspect that it contains the analog channel.
The analog channel likely does not have a tone programmed - and will match on any transmission. I suspect this is the channel that is passing undecoded digital audio. I suggest avoiding this channel - or remove it from your programming.
I'm not convinced that this is the case. How have you determined that it is stopping on the NXDN channel? I suspect that the channel that is passing undecoded digital audio is programmed as analog - not nxdn.
Having the same frequency programmed multiple times can be very confusing. While you troubleshoot why you are not receiving DMR on this frequency, I suggest that you delete or avoid the other channels programmed with 155.7. (You can add them back when you are done troubleshooting if you want).
Please attach a copy of your programming file (either sentinel or proscan). I'll take a look at it sometime tomorrow (Monday) if I get a chance.
Here is a video of what the scanner is doing when on those DMR channels including the 154.8600. my sds100 just is not playing and dsdplus is playing those channels. and the sds100 is showing it's dmr and what color code and slot.
Video
When dsd+ is playing the dmr channels, what is the content of the voice transmissions? Is it law enforcement? Can you tell what agency(s) is on each channel?
Please show a screenshot from dsd+ for each of the dmr frequencies (153.125, 154.86, 154,55, 155.7) showing the event log and channel activity windows.
Maybe this will help provide some insights and cut through some of the confusion.
AngWay
Curious
Buchanan, Va
Just to triple check - do you have Custom 1 service type enabled? You have Town of Clintwood (155.7) set to Custom 1.
Yes it is programmed in three times but each has a different tone the clintwood one has a tone for the analog and the digital so it does have a tone. i know if it didn't have one it would match whatever so i have made sure it has one.
every since i started with dsdplus fastlane which was over 6 months ago 155.7000 and 155.8000 would always show NXDN and it was encrypted but now for some reason dsdplus has started showing those as DMR i don't know why.
I have avoided them and tried that before alot of the stuff i have tried i have tried putting in just that one freqs in a seperate fav lists . i looked in the uniden folder for the programming file where exactly is the files that u want and i will post them.
Yes it's law enforcement , i'm not sure what agency
Here is screenshots of all freqs when traffic comes up it's not encrypted traffic
RMason
Please show me the programming for the analog channel
AngWay
Curious
Buchanan, Va
is this what u are talking about?. the ones u see with a color code or digital search those was Ran in the database and i had to changed them
RMason
You can export your favorite list from sentinel: (please include all of the systems in the favorite list)
To Export a list click File > Export to hpe file... Select the list you wish to export and click OK. Select the systems to export and click OK.
AngWay
Curious
Buchanan, Va
AngWay
Curious
Buchanan, Va
here. The big problem is how when the sds100 scans and it gets to the dickenson county with the DMR freqs it's really slow and it hangs on those freqs forever. it doesn't do this with p25 or nxdn freqs
  • Sentinel Fav.zip
RMason
does the sds100 waterfall show anything interesting with these frequencies?
RMason
I still can't figure out why if i put dsdplus on 155.7000 i will hear traffic but if i put the sds100 on that freqs i don't hear anything
No not really here is what it does and it will do that noise you hear at the beginning
I do wonder why isn't it showing a signal in the waterfall?
I am beginning to think that you simply do not have strong enough signal for the sds100 to decode. No signal is showing in the waterfall in your video.
Is the sds100 connected to the same antenna as dsd+?
Put the sds100 on 154.86 (or 155.7) in waterfall mode. Tune dsd+ to the same frequency. Wait until you get a voice transmission on dsd+. Do you see signal on the frequency in the sds100 waterfall? (I choose 154.86 because you have shown a dsd+ screenshot with it receiving voice transmissions, but you say you get voice transmission on 155.7). Do you ever see a signal on the waterfall? Please provide a screenshot of dsd+ event log showing voice on 155.7. Also provide screenshot of sds100 waterfall when dsd+ is showing voice transmission.
The sds100 is portable. You may want to take it for a drive toward Dickenson County to see if you start receiving something. (You will want to first listen to the transmissions on dsd+ to identify where they originate from. Take note of addresses, cross-streets, town names, etc. Being able to identify transmissions by listening is a good skill to develop)
AngWay
Curious
Buchanan, Va
Ok i did the best i could here and i recorded 4 clips i have dsdplus and proscan both running and when u hear the audio u will hear a echo because it's both the audio from dsdplus and from my sds100.
U can see there is no signal showing at all in the sds100 waterfall but there is in dsdplus,it does show as dmr on the sds100 and from time to time u can hear a blurrrrrr sound. oh and 153.1250 and 154.8600 and 155.7000 all three show DMR and have the same traffic playing on all three.
Video
Video
Video
Video
dave3825
Suffolk County NY
Delete all entrees of that freq.
Create an entry called 155 700 Analog. Set audio type to analog only with tone search.
Create an entry called 155 700 DMR, Set audio type to Digital, Set Color code search.
Create an entry called 155 700 Nxdn, Set audio type to Digital, Set Ran search.
Write to scanner. Let it run a few days and review recordings.
RMason
Wait a minute - I think I missed something....
Are you getting voice audio on the sds100 on the these frequencies (153.125 and 155.7) while in waterfall mode? But not when you have it programmed as a dmr channel?
