Galaxy 959 SWR
UnidenBC92XLT
Arkansas
I have a Antron 99 with the base at 30' in the air. 50' of RG8U Foam running to my Galaxy 959. On channel 1 the SWR is 1.2 and on channel 40 the SWR is at 2.0. Is this ok or do I need to adjust the tuning rings on the antenna? Do they need to go up or down? Thanks in advance.
UnidenBC92XLT
Arkansas
Well I managed to get them down to 1.0 on CH1-33 and 1.2 on CH34-40 So its all good now. But the rings are almost all the way to the top now.
jaspence
Michigan
SWR
If you are using a standard CB SWR meter, the results can vary from meter to meter. A 1:1 ratio is almost impossible to really achieve, especially over a range of frequencies. Even getting below 1.5:1 is considered good for the overall band width. The following link will give you some good info. SWR and TRANSMITTERS - What is SWR all about? Making Sense of SWR Readings
Blackswan73
Central Indiana
I assume you are talking about the SWR reading on the radio. Those meters can be be somewhat inaccurate. A Bird 43 is the most accurate, but for your purpose the meter on the radio will most likely be close enough. For me I would still check it with a stand alone meter. Like a Workman, Opek, Astatic, or Para Dynamics. As a bonus, the Para Dynamics test center with the three separate meters, will also work on 2m if you ever happen to decide to get your ham ticket
UnidenBC92XLT
Arkansas
Ok just checked it with my Workman HP201S and it shows 1.4 on Channel 40 and 1.5 on Channel 1. Thats using a real junky jumper the only one I have. The 1.0 and 1.2 was with the RG8 running directly to the radio. The meter on the radio also showed higher with this other meter hooked up inline.
Blackswan73
Central Indiana
This meter checks power, modulation and SWR, from 25mhz., all the way through 2m
Blackswan73
Central Indiana
Notice, I did not mention a Dosy. For what you pay these days for a Dosy, you can buy a decent used Bird 43
Blackswan73
Central Indiana
You should be good to go!
