Not Really. Every LE agency in Knox and Seiver counties use fulltime encryption.Is there anything that would be worth programming into my unication before a trip? I am seeing lots of DMR and encryption in the area. Is there anything in the clear or interesting on the state system?
TACN has THP and Anderson and Blount counties which are mostly clear. Not sure about Jefferson county other than the fact they're using Land Air's NXDN system now. Not sure if you have a VHF G5, but if you did I would highly recommend putting in the GSMNP P25 Phase I repeaters. There are about conventional 10 sites all linked for parkwide coverage on the TN and NC sides. Even during the park closure, the system has been very active, with very minimal usage of secure. The NPS Rangers also perform a lot of traffic enforcement outside the park in the area there.Is there anything in the clear or interesting on the state system?
I'm not aware of any changes.I heard that the Blount County Sheriff’s Office has made changes recently (Jun-Aug 2020) that makes monitoring voice communication more difficult. Can anyone describe the changes?
I'm hearing full-time encryption on all channels for the online scanner. (I'm out of state, so have to listen online.)I heard that the Blount County Sheriff’s Office has made changes recently (Jun-Aug 2020) that makes monitoring voice communication more difficult. Can anyone describe the changes?
Nope. I have been listening to BCSO all week. Both the Communications Center and the units are mostly clear. Blount County has been using partial/selectable encryption for years so it may seem like full enc at times but it's not.I'm hearing full-time encryption on all channels for the online scanner.
I'm definitely hoping that's the case. I've been listening off and on over the past few days and every time its been encryption garble.Nope. I have been listening to BCSO all week. Both the Communications Center and the units are mostly clear. Blount County has been using partial/selectable encryption for years so it may seem like full enc at times but it's not.
As far as I know the following encryption policy is still in place at the comm center:I'm definitely hoping that's the case. I've been listening off and on over the past few days and every time its been encryption garble.
I am using a sds100 scannerIs Gatlinburg Police in full encryption on NXDN? Last time I was there last spring I couldn’t pick up their channel and I did purchase the key for NXDN. Is there something in the settings that I need to change to be able to hear or they just fully encrypted? I can see them keying up but can’t hear anything.
Thank you
Their conventional repeater on Ski Mountain and their channel on the Land Air Trunking System are fully encrypted.The encryption symbol shows up on both GPD channels in Jefferson County radios. Same thing for SPD conventional and their trunking channel. At least one of the sheriffs office conventional repeaters are encrypted as well.I am using a sds100 scanner
They tone them out and usually station 1 acknowledges the page. The staff decides what is appropriate to send. If they need additional they tone for manpower. Sometimes a Battalion Chief gets on the radio and directs them if needed. It works well."You can also monitor Seymour VFD on 154.310. They are dispatched by Sevier Central, Knox Fire (AMR/Rural Metro Dispatch, and Blount Comm Center "
How does that work? Does the officer of the day acknowledge all pages - and decide which units go to which calls?
The Sevier county Fire Dispatch channels on nexedge are encrypted as well. I have not been hearing the Fire paging channel lately, I have no idea why. I have been hearing when EMS gets paged with fire on the EMS Analog channel. Pigeon Forge Police is the only LE channel you can really listen to. NPS LE monitors Land Air and sometimes they repeat what the other agencies say, if you are interested in monitoring them. The county interagency frequency for dispatch centers is a really good one to monitor as well.Thanks for clearing that up and it sounds like Pigeon Forge and some fire departments are good to listen to there.
As a former member of Seymour, this is correct. Dispatch sends out the tones, then announces fire, or EMS response. It is then up to the crews to decide who goes, from trucks to stations. And dispatch has no call, or say, and because of that (no offense) it was a very well run dept. when it came to the initial response. No interference form dispatchers.They tone them out and usually station 1 acknowledges the page. The staff decides what is appropriate to send. If they need additional they tone for manpower. Sometimes a Battalion Chief gets on the radio and directs them if needed. It works well.
You can hear the State Police as well as Pigeon Forge PD fine, as well as a few other things.
