GBCAT - Computer Aided Transceiver
0xFF1E071F
GBCAT is PC software for controlling amateur radio devices through a COM/USB port or through a TCP/IP network, with the ability to transfer a 2-way audio signal over a TCP/IP network. GBCAT is composed of three parts: the base module, the extended command set A, and the extended command set B. In the registered version, all modules retain their functions, regardless of whether they are displayed on the screen or not.
GBCAT v0.9b5 in Remote Mode
The GBCAT installation package also contains: an integrated Remote Desktop Connection, an IPCOM Server/COM2IP Redirector, and an Audio Server/Client.
Hardware requirements:
A PC powered by a single core processor, (recommended CPU clock is 1.7 GHz or higher), 2 MB RAM, a COM or USB port (USB to COM adapter if required), TCP/IP network card (for wired or wireless operation), and any of the supported radios connected to the COM port by a suitable cable/adapter and powered on.
Software requirements:
Any of the following operating systems: Windows XP(tm), Windows 7(tm), Windows 8(tm). Installed Microsoft(tm) .NET Framework v4.0 Client Profile.
GBCAT development has been ongoing for two years, and takes all of the author’s free time; nevertheless, GBCAT is free of charge.
Rigs.supported.by_GBCAT
Supported radios:
Yaesu FT-857/857D
Yaesu FT-817/817ND
Yaesu FT897D
Icom IC-706MKIIG
Kenwood TS-2000 (from v0.9b6)
Kenwood TS-590S (from v1.2)
DOWNLOAD
