General BKR9000 Things
PacScan
Los Angeles
Hi all,
I have now had the radio for a few months, just wanted to put this thread out there to see what others think about all this:
1. Has anyone noticed that the BKR9000 audio quality is a bit more static/worse quality when running at lower volumes on a P25 trunked system? (compared to a Motorola APX)
2. When running non-affiliated, it would be great for the site select menu option to display ALL sites regardless of signal. Right now I may be in a place where I know there is signal, but the radio decides to lock on a further site. I have to physically move for a few minutes before the radio decides to jump since I can't manually select the site because it does not appear in the list. Then I can return to the same location I was at perfectly fine with full signal as it should have been in the first place. Not sure if anyone else has run into this issue.
3. Finally, would love an easier way of making scanlists via RES. The software constantly seems to mess up scanlist numbers which then makes the zone linked scanlist #s messed up (does not auto-change to the updated number).
Anyone else experience any of this?
PacScan
Los Angeles
Would you send this to Customer Service please, so then you can get direct answers. Thank you
I did submit their online form a month back, never heard anything. Will go ahead and manually email them to see if I get anything back again.
