Parkwide 1 is 166.375 rx 167.025 tx. Parkwide 2 is162.6125 TX 167.025 tx Park wide 1 at Numa lookout in north fork. Parkwide 2 at Apgar lookout tower. Parkwide 1 scalp lock parkwide 2 two med , 1 st mary and on so forth
I worked for the park service and got info directly from a park radio. There is no output Pl tone. The radio shop did that in case stations were still using the old park direct freq. I figured they would move to kaliapell dispatch but I know for a fact unless the radio tower site was affected kalmar dispatch also uses parkwide. Cause I would hear our fire crew( glacier park) call kalispell disp. With size ups and kal disp would use it to call forest service crews in the park area or if they couldn't reach on other channels. TAC 1 is a channel used for incidents probably not the fire but radio shop had several repeaters on trailers and I believe back packs that they set up for fires and SAR. The avalanche fire back in 2013 I believe we used tac 1 repeater watched minute man helicopter pick up the trailer and fly it out to the area.
