GM Data Interface causing RFI interference in Silverado
ezdropper
Maryland
I installed an aftermarket car stereo in my Chevy Silverado and had to use a Metra Axxess GMOS-01 GM Data Interface to retain the chimes. I've noticed that it's causing all kinds of RFI interference on my scanner, mainly on the VHF frequencies. Tried relocating it to different places in the truck but still gettting all kinds of noise on VHF.
Was wondering if anyone else has had the same problems?
izzyj4
Ova here
I don't have a Chevy but a basic install question for you. Where are you getting your power from, the fuse block or direct to the battery for your scanner? You could be getting the interference though the power lead. If you can, I would get the power to your scanner direct from your battery, if you haven't done that already.
Just a thought.
sfd119
What year Chevy?
My 2014 has taken a huge hit on FM stereo reception compared to my 2008 and have noticed VHF problems on all my radios/scanners as well. Doing a bit of research on this there was a log of other people with FM problems that were never really rectified on these yearish trucks.
zrock
Were are your antenata mounted
Sent from my SM-G950W using Tapatalk
zrock
One heck of a set up... I would almost bet one of your antenna cables running down the side pillars is picking up the interfearence. I found my antenna had to be behind the centerline of cab and cable run down center of truck. Anyware else and I had issues
sfd119
The two scanner cables are running down the passenger A Pillar while the rest are split running down the rear pillars. Both the scanners and radios have less range compared to my 2008. FM reception is terrible too but its a widespread issue.
mccleway
Kinda late to the game here, but if OP is still having issues, I'd recommend wrapping the Metra unit in a small mylar bag to see if that's where the interference is coming from.
