GMRS Frequency List
Aviation_Scanner
WSEY205
Houston, Texas
Is this list of GMRS frequencies complete?
I would like to program these into my SDS-100 scanner (& GMRS Radio for that matter, once I get the right programming cable for it) and just wanted to make sure this list had all the GMRS frequencies.
Can the repeater frequencies with no channel assignments still be used?
Those are the repeater inputs. They can -only- be used for repeater inputs, not for simplex.
You could plug those into your scanner and listen to see if someone nearby is accessing a repeater, or to hear if someone is doing something stupid on the inputs.
  • Like
Reactions: wtp
nd5y
Wichita Falls, TX
Don't GMRS approved radios come pre-programmed with the correct frequencies?
Depends on the radio. Cheap consumer-grade radios that don't transmit on other frequencies do. The Kenwood and Motorola commercial radios that also have Part 95 certification don't come with GMRS frequencies.
Aviation_Scanner
WSEY205
Houston, Texas
And just to add, my radio did come with the GMRS frequencies pre-programmed with all the GMRS frequencies.
I will just need to add GMRS repeaters to the radio once I get the right programming cable.
