GMRS Frequency List
Aviation_Scanner
WSEY205
Houston, Texas
Is this list of GMRS frequencies complete?
I would like to program these into my SDS-100 scanner (& GMRS Radio for that matter, once I get the right programming cable for it) and just wanted to make sure this list had all the GMRS frequencies.
Can the repeater frequencies with no channel assignments still be used?
Those are the repeater inputs. They can -only- be used for repeater inputs, not for simplex.
You could plug those into your scanner and listen to see if someone nearby is accessing a repeater, or to hear if someone is doing something stupid on the inputs.
  • Like
Reactions: wtp
nd5y
Wichita Falls, TX
Don't GMRS approved radios come pre-programmed with the correct frequencies?
Depends on the radio. Cheap consumer-grade radios that don't transmit on other frequencies do. The Kenwood and Motorola commercial radios that also have Part 95 certification don't come with GMRS frequencies.
Aviation_Scanner
WSEY205
Houston, Texas
And just to add, my radio did come with the GMRS frequencies pre-programmed with all the GMRS frequencies.
I will just need to add GMRS repeaters to the radio once I get the right programming cable.
Coffeemug
Warminster BUCKS Co. PA
I haven't really read the latest updates on the FCC's Part 95E the General Mobile Radio Service, but I'm sure the FCC hasn't added additional channels to the service. However, I notice the Amateur Radio 220 Band is slowly being occupied by other services, such as the FREDs or EOT Devices for Freight Railroads and I'm sure the PTC Positive Train Control Systems. I didn't any recent changes for GMRS or MURS.
nd5y
Wichita Falls, TX
PTC and other railroad stuff isn't in the amateur band. There haven't been any changes to the 222-225 MHz amateur band since the 1990s when 220-222 MHz was taken away and 219-220 MHz added on a secondary shared basis.
Coffeemug
I may have gotten a few facts wrong in regard to how the railroad industry use the 220 band, but the railroad transportation industry utilizes the 220 band. I could have sworn that I've seen a 220 frequency within the Amateur Radio Spectrum used in the Remote-Control Devices for Yard Switch Engines. Maybe I'm wrong again, heck I'm always wrong!
808Beachbum
"Band" is somewhat deceptive, as there are many, many bands as seen on this US chart. Many bands are further broken down by type of transmission, and/or freqs designated to specific business sectors or companies.
sempai
Iowa City, IA
it's already in Sentinel, man. i added my own gmrs system to my scanners but i use the national defaults for those services too and you don't need to do anything else but i use squelch tones on my household system that i want to log and record as such instead of other tones or lack of them.
chirp can download lists for frs/gmrs/murs for any supported radio!
