GMRS input and output frequency help
JackRoberts23
Was Justin Schmidt
So I'm new to GMRS and was just looking for some clarification. If I wanted a repeater and I had the frequency 462.675, that is the receive frequency correct? If that's true, I'm assuming 467.675 is the transmit frequency for the repeater. If anyone can help me clarify, that would be great!
prcguy
The 462 range is where the repeater will transmit and the 467 is where the mobile would transmit. For simplex on the same channel the mobile would transmit at 462 so people monitoring the repeater would hear it.
sallen07
Rochester, NY
If you are looking at it from the perspective of your HT or mobile radio, that is correct, yes.
Your radio transmits on 467.675 and receives on 462.675.
The repeater recieves on 467.675 and transmits on 462.675.
JackRoberts23
Was Justin Schmidt
Thank you that was really helpful!!
ecps92
Taxachusetts
and generally ALL programming should be looked at from the Subscriber units (Users) vs the Infrastructure (Repeater) otherwise you end up with the confusion as well all see by the OP
JackRoberts23
Was Justin Schmidt
I have my radio set up as follows
Rx: 462.575 pl67
Tx: 467.575 pl 67
It’s not working. Does anyone have any ideas?
Rx: 462.575 pl67
Tx: 467.575 pl 67
As mentioned elsewhere:
Make sure you have the correct frequencies for the repeater.
Make sure you have the correct TX PL tone.
REMOVE the RX PL tone and just run in carrier squelch to see if you can hear the repeater. Not all repeaters retransmit the PL tone. Some repeaters use a DIFFERENT tone on the output.
When in doubt, contact the repeater owner and they will give you the correct information.
JackRoberts23
Was Justin Schmidt
Will do
JackRoberts23
Was Justin Schmidt
A silly question, are you certain that you are reaching the repeater?
Do you have the correct "tone" set to open the repeater once you reach it ?
Yes I was standing 1000 feet away from it and I’m pretty sure I have the correct tone
KevinC
Other
Super Moderator
Home
Rx: 462.575 pl67
Tx: 467.575 pl 67
So is it 462.575 or 462.675?
JackRoberts23
Was Justin Schmidt
Seems like this guy has as much trouble keeping track of frequencies as he does his own name. 🤡
Seeing as you guys don’t like when I ask questions, I changed my username
