- Joined
- Jul 18, 2016
- Messages
- 31
- Reaction score
- 5
Can anyone recommend a decent outdoor antenna for a handheld unit? I get that i would be running a wire from the inside of my house to the outside. Just going for better range
| 154.13000 | KCC349 | RM | 203.5 PL | Stamford FD | Fire Simulcast | FMN | Fire Dispatch |
| 769.03125 | WQGH338 | M | 71.9 PL | Stamford FG1 | Stamford Fireground 1 | FMN | Fire-Tac |
| 774.93125 | WQGH338 | M | 107.2 PL | Stamford FG2 | Stamford Fireground 2 | FMN | Fire-Tac |
| 769.04375 | WQGH338 | M | 123.0 PL | Stamford FG3 | Stamford Fireground 3 | FMN | Fire-Tac |
| 774.98125 | WQGH338 | M | 146.2 PL | Stamford FG4 | Stamford Fireground 4 | FMN | Fire-Tac |
| 854.16250 | WPUE865 | RM | 67.0 PL | Stamford FDR | Stamford Fire Backup | FM | Fire-Tac |
| 769.00625 | BM | 179.9 PL | Stamford FD Supr | Stamford Suppression | FMN | Fire-Tac | |
| 154.32500 | RM | 114.8 PL | Stamfrd FDBU | Volunteer Fire Department Backup | FMN | Fire Dispatch | |
| 775.99375 | WQGH335 | M | Stamford PS1 | Public Safety Tactical 1 | P25 | Multi-Tac | |
| 794.05625 | WQGH335 | M | Stamford PS2 | Public Safety Tactical 2 | P25 | Multi-Tac | |
| 794.06875 | WQGH335 | M | Stamford PS3 | Public Safety Tactical 3 | P25 | Multi-Tac | |
| 805.99375 | WQGH335 | M | Stamford PS4 | Public Safety Tactical 4 | P25 | Multi-Tac |
The antenna won't be too far from the unit. I will be listening only. I actually have something I picked up from amazon I thought about hanging up outside. https://www.amazon.com/gp/product/B07K7DBVX9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I'll be listening to fire calls.
As much as i would love to mount something to the house, I can't. I rent...lol Hence why I was looking for something I could put up and take down with minimal damage
What type of coax and adapters do you recommend?
How long will the cable run be? (In feet)What type of coax and adapters do you recommend?
maybe 15-25 ft. I have the 325P2
How far outside of Stamford are you? Also do realize you will probably not hear the fire ground channels I think they are simplex.The antenna won't be too far from the unit. I will be listening only. I actually have something I picked up from amazon I thought about hanging up outside. https://www.amazon.com/gp/product/B07K7DBVX9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
154.13000 KCC349 RM 203.5 PL Stamford FD Fire Simulcast FMN Fire Dispatch 769.03125 WQGH338 M 71.9 PL Stamford FG1 Stamford Fireground 1 FMN Fire-Tac 774.93125 WQGH338 M 107.2 PL Stamford FG2 Stamford Fireground 2 FMN Fire-Tac 769.04375 WQGH338 M 123.0 PL Stamford FG3 Stamford Fireground 3 FMN Fire-Tac 774.98125 WQGH338 M 146.2 PL Stamford FG4 Stamford Fireground 4 FMN Fire-Tac 854.16250 WPUE865 RM 67.0 PL Stamford FDR Stamford Fire Backup FM Fire-Tac 769.00625 BM 179.9 PL Stamford FD Supr Stamford Suppression FMN Fire-Tac 154.32500 RM 114.8 PL Stamfrd FDBU Volunteer Fire Department Backup FMN Fire Dispatch 775.99375 WQGH335 M Stamford PS1 Public Safety Tactical 1 P25 Multi-Tac 794.05625 WQGH335 M Stamford PS2 Public Safety Tactical 2 P25 Multi-Tac 794.06875 WQGH335 M Stamford PS3 Public Safety Tactical 3 P25 Multi-Tac 805.99375 WQGH335 M Stamford PS4 Public Safety Tactical 4 P25 Multi-Tac
| 1 (1) | 002 (2) | Stamford Simulcast | Fairfield | 851.1125 | 851.3875 | 851.6625 | 851.7625 | 852.0875 | 852.3375 | 852.7875 |
| 852.8125a | 853.0875a | 853.3375c |
| 23507 | 5bd3 | D | Stamford FD | Fire Dispatch | Fire Dispatch |
| 23508 | 5bd4 | D | Stamford FG1 | Fireground 1 | Fire-Talk |
| 23509 | 5bd5 | D | Stamford FG2 | Fireground 2 | Fire-Talk |
| 23510 | 5bd6 | D | Stamford FG3 | Fireground 3 | Fire-Talk |
| 23511 | 5bd7 | D | Stamford FG4 | Fireground 4 | Fire-Talk |
| 23513 | 5bd9 | D | Stamford FDT1 | Fire TAC 1 | Fire-Tac |
| 23514 | 5bda | D | Stamford FDT2 | Fire TAC 2 | Fire-Tac |
| 23515 | 5bdb | D | Stamford FDT3 | Fire TAC 3 | Fire-Tac |
| 23516 | 5bdc | D | Stamford FDT4 | Fire TAC 4 | Fire-Tac |
| 23522 | 5be2 | D | Stamford EMS | EMS Operations | EMS Dispatch |
I am right in Stamford. I hear the fire callsHow far outside of Stamford are you? Also do realize you will probably not hear the fire ground channels I think they are simplex.
OK, won't take much. Even RG-58 would be fine, and plenty flexible.
But if I was me, I'd probably get some LMR-200 or LMR-240UF. The LMR-240UF is their UltraFlex cable and will be less stiff and easy to roll up when you are not using it.
The base adapter I linked to ( https://www.theantennafarm.com/cata...oduct_info&cPath=481_483_484&products_id=7531) has a female N connector on the bottom. So one end of your coaxial cable would need to have a Male N connector on it.
The other end would need to have whatever mated with your scanner.
These guys will make custom cables for you:
If you have the correct tools and experience, you can certainly make your own. If not, it's worth having someone fabricate the correct cable for you. Ideally you want to avoid using adapters, so getting a cable built with the correct connectors on the end will save you some headaches down the road.
Get a few more feet than you think you need. For the LMR-240UF, you are looking at $0.99/foot, so not a big deal.
Get the optional heat shrink tubing over the connector crimps. It acts as a strain relief and will extend the life of the cable. It's only $10.00 extra, but it's well worth it. I use it when I make my own cables.
Pick out the connectors you need. Make sure a Male N on the antenna end, and the correct end to match your scanner. The cable is fairly light and flexible, so connecting directly to the scanner shouldn't be an issue.
You'd be looking at around $50 all said and done for that cable. You could make it yourself, but you'll pay more than that for the crimping tools, plus all the connectors you'll waste practicing doing them.
Or, find someone local that will make the cable for you.
| Item | Description | Price | |
| LMR-100A-PVC Manufacturer Times Microwave Model # LMR-100A-PVC Product Description 50 Ohm Coaxial Cable - Low Loss Flexible LMR-100 Cable The Times Microwave LMR-100A-PVC LMR100 flexible, low loss coaxial cable offers similar performance compared to corrugated copper... | $0.49 | change |
| Manufacturer TerraWave Model # CON-07-100 Product Description N Male Cable Type RG-174, 188, 188A, 316/U; Belden 7805A, 8216, 83269, 83284, 84316; Times LMR-100A Connection (Body) Crimp Connection (Pin) Crimp Construction (Body) Nickel Construction... | $6.95 | Change |
| Manufacturer Emerson Network Power Model # CPM-88-19 Product Description BNC Male Cable Type RG-174, 188, 188A, 316/U; Belden 7805A, 8216, 83269, 83284, 84316; Times LMR-100A Connection (Body) Crimp Connection (Pin) Crimp Construction (Body) Nickel ... | $2.75 | Change |
Yeah good call. Didn't even see that i clicked the wrong cable. Now to really mess up the mix. I was thinking of getting this....If your scanner has a BNC connector on it, yes, that'll work.
Any specific reason you chose LMR-100? You will lose 70% of your received signal just in feed line losses. RG-58 would perform better and you may find that the cable and connectors are cheaper since it's more popular.
| Qty. | Item Name | Unit | Total | ||
Larsen NMO150/450/758 | $49.95 | $49.95 |
Laird Technologies MBCN | $29.95 | $29.95 |
