As anyone in the Akron area knows, there has been a Motorola Type II system online for years for Goodyear Tire and rubber. This system is at:
https://www.radioreference.com/apps/db/?sid=1364
However, the license (WNYV657) was modified in 2009 to change all frequencies (rebanded ?) and again modified in 2012 to change emissions to DMR.
Incidentally, we have had nobody submit any updates to this system since before that time.
This leads me to believe that the system is (a) probably no longer a Motorola Type II system and (b) is likely on the new frequencies as either a Motorola Capacity Plus or Connect Plus system.
If you are in the Akron area, please check the following frequencies for the presence of a control channel (which would likely be a DMR control channel). If it's a Capacity Plus system, there will not be any 24/7 control channel and frequencies will only be active with speech / data / beaconing at various times. But if it is a Cap+ site and you are using DSDPlus to check the frequencies, it will clearly tell you if it is Cap+ or Con+.
859.9375
860.1875
860.7375
Any updated info should be submitted to: https://www.radioreference.com/apps/submit/?sid=1364
Appropriate changes will be made by an Ohio admin pending any submissions. If the submissions indicate it has changed to DMR, this system will be deprecated and a new system will be created to replace it in the DB.
I have a high degree of confidence that the above frequencies are active with DMR signals, so if you are within earshot of that system please check it out and provide us with some details.
859.9375
860.1875
860.7375
