I seem to recall an issue with the chip set used in some programing cables not getting along with Windows 11. Make sure you double check this if you will be using Windows 11.Only other thing I need to know about is programming and a cable. Is there a recommended programming cable? Should I use Chirp or the BTech software? I’m totally clueless about programming
Chirp is open source I believe and is available for Windows, Linux and I think Mac.
The BTech software most likely Windows only.
There may another software choice RT systems I think it is called.
Personally I use the OEM software on a dual boot Windows 10 and Linux computer that I only use the Windows for radio programing and keep it off line so it does not update or get malware.
I tried the RT software and did not like it but lots of people do. It is suppose to be easy to use but I found it limiting.
