GP68 Display problem
Recon_Grim
I just received a Motorola GP68 radio. However, before I can even try to program it, pressing the "X" button to attempt to change the display mode from Channels to Frequencies makes the same sound as if the keypad is locked and does nothing. It is not in Scan mode, and the keypad is not locked, and I cannot for the life of me figure out what exactly I am doing wrong. I figure it's something simple (I'm new to this kind of thing, so it probably is), but I thought I'd ask here anyway.
2009KVFD976
It might have been set to not allow user progamming. I had the same problem and opened it up to remove the R417 jumper and it worked fine again...
Tesla70
Port Macquarie....NSW...Au
Paul
Having Major Problem's with 2 Motorola GP68...UHF..Radios...When i Input the first frequency into Ch.01...Lets say 438.525 with Negative Offset and all other settings it accepts settings and i can recall it....Next Frequency is 433.525 with same settings, it is then Programmed into Ch.02....But then here is the Problem....It then Overides the Settings in Ch.01 or any other Channels in Radio..."Duplicates all Channels"
Has any one in the Forum,s have any Solutions to this Frustrating Problem..
Cheer's Paul
VK2UPR
2009KVFD976
Try a factory reset. Turn it off then back on and hold down the mem button at the same time. Then after it powers up, press the PTT and enter 13579. This resets the radio.
Tesla70
GP68...Programming Frequencies
Have tried Full Reset on Radio....Still will not work...On another Forum i noticed another person had the same problem...He had no Reply to his question...Just hope that the "Brains" of the radio are not corrupted...Do not know of any one with a similiar radio that we could "Clone"
W2NJS
Washington DC
The so-called "programming manual" for the GP68 is available online somewhere. In it's best working iteration it's always been a real bear to program via the keypad, which is the only way you can do it. Start Googling and you'll find the information.
Recon_Grim
I'm extremely frustrated. I've been looking for an hour, and the one single drawing of the circuits on the entire internet has no visible relation to the radio I have. Does anybody have an actual picture of the location of R417? I need the answer soon, please, I really don't feel like using a talkabout this weekend.
