BCD325P2/BCD996P2: GPS
dave3825
Suffolk County NY
tvengr
Well Known Member
Baltimore County, MD
GPS plugs into the rear serial DB9 port. From the manual:
The GPS device must have a serial (RS-232) output, and be capable of outputting standard NMEA-0183 v3.01 compliant location data, and GGA/RMC data sentences at 4800 bps. Make sure that the cable terminates in a female, 9-pin serial connector and you select the correct baud rate (4800 bps) for the rear serial port.
The port can be set for other baud rates than just 4800. The new Uniden GPS module uses 9600.
hazrat8990
Wyoming
If you're handy with a soldering iron, there are a few threads on here that detail installing an internal GPS module and chassis mount SMA connector.
