For those who use Wifi radio to monitor scanner feeds, there is a new Wifi radio available from Grace Digital called the Mondo. It's a lot like the Logitech Squeezebox, but a little more advanced in some respects, but not programmer friendly for new apps. It works well, sounds good, and looks great. A battery pack is also available for portable use, just like the Squeezebox. The Mondo also accepts USB input that can double as an Ethernet connection via an optional adapter, so you could just link it directly to a PC if you wanted to just play the feed through the radio. It has stereo red/white RCA outputs, and a 1/8" stereo jack, with Mono or Stereo settings via the menu. The Squeezebox includes the Ethernet connection, but only a 1/8" audio input/output port, and headphone jack.
Grace Digital has a Reciva page that allows you to input the streams you wish to listen to. You can also save them to one of ten presets on the front of the radio for easy access from the front panel near the speaker. There are ten presets available, five direct and five from a shift key.
To copy the stream, you just browse to the RR live feed of interest, select the links, select the drop down menu for Player Selection, select Windows Media Player, then right click on the speaker and copy the link. Then once you have registered your Reciva account and created an entry in the My streams folder, you can copy the link into the folder and save it. It can take up to 48 hours for the link to show up, but mine were almost instantly added to the list.
I was able to input my favorite Radioreference and ATCLive streams in the web page before the radio arrived, and they were available once I updated the radio firmware from the radio internet connection.
Setup was easy and the radio found my Wifi connection quickly. Initial setup out of the box was about ten minutes.
My only wish is that it had support for apps, like the excellent ScannerBox app. available on the Squeezebox.
Happy Holiday Scanning everyone!
