GRE Programming Cable
fireant
Copland
Went to use my usb cable today to do some programming however, maybe someone on here can refresh my memory was there a light that would light up once you plugged in into the usb port? I am getting no light and seems my cable is dead. I have tried other types of usb cable and they seem to go into the usb port further then the GRE does. I have not reprogrammed my radio in sometime so I had not noticed this sooner. Any clarification would be appreciated if its dead then off to radio shack I go unless I can use a the older RS232 cable then I will be fine.
thanks
Fireant
gmclam
Fair Oaks, CA
I don't get a light from mine except when there is an active transmission. Both lights flash when sending to the scanner, and one flashes when downloading from the scanner.
fireant
Copland
Thanks for the reply I opened up the casing around the circuit board and had to repair a loose connection now its working fine. I was not getting it to do anything earlier. Just glad it saved me $30 bucks but was thankful if I did have to buy a cable they was on sale for $5 off. Thanks again for looking.
fireant
