GRE PSR 500 and Edacs Icalls
trido
Retired 32 years scanner sales
Southern In
Are you guys and gals hearing Edacs Icalls ok?
I am not hearing them at all.
When a unit first keys down I see digits/letters for just a split second and never hear voice at all.
Not sure if firmware needs to address this or everyone else is fine with Icalls
thanks
scan-pa
RRDB Admin
Lebanon, Pa.
thanks
What Audio Modulation Mode are they using for there I-CALLS? Analog FM, ProVoice Digital, OpenSky Digital, Aegis Digital, Digital, P25 Digital?
trido
Southern In
scan-pa said:
What Audio Modulation Mode are they using for there I-CALLS? Analog FM, ProVoice Digital, OpenSky Digital, Aegis Digital, P16 Digital, P25 Digital?
Analog FM
All unidens here icalls fine
I have added a wildcard talkgroup set to Private I think that is all that is needed correct?
scan-pa
RRDB Admin
Lebanon, Pa.
not very many I-Calls on the Analog / Provoice combo EDACS system here in Lebanon Pa. However I have set the PSR-500 to latch and alert on any I-Calls that are detected by the scanner.
Someone else with a busier system might be able to help, before I get one here.
trido
Southern In
Lets be sure I have it right all we do is make a wildcard group right set it to PRIVATE thats it for icalls.
scan-pa
RRDB Admin
Lebanon, Pa.
Jeff,
Thats what I did.
scan-pa
RRDB Admin
Lebanon, Pa.
Just got my first EDACS 800 Analog I Call off the First Energy / Met-Ed Trunked system.
Works great, followed 2 seperate full conversations without a problem.
jameshober
Does the scanner show the radio id when using the wildcard for I calls.
jameshober
Has any one set a tgrp to private and specify a radio id to watch for. This would be good late at night I could just listen for a deputy chief. Then change to an other v folder if something is happening.
rdale
Lansing, MI
Radio doesn't work that way. It would only hear if that user was making a private call.
RoninJoliet
ILL
As mentioned in another post here on the Will Co ILL Edacs 800 6 channel wide trunk system i see the ICALL # but no audio....Has good audio on my 246 and 396...Its set to Wildcd PC also...On this same system a friend and I both had to adjust the Edacs-Unmute in F-GLOB to below "10", the default is "18" or we would miss the first word in each transmission.....
