GRE PSR-500 CPU firmware
Lwolf1313
El Mirage, AZ . USA
I was reading a text file called PSR-500 _info.pdf and it stated the newest CPU firmware update is 1.6. Does anyone know where that version is available or how to tell what CPU version I have??
fxdscon
¯\_(ツ)_/¯
To see what firmware you have in your scanner...
From the owners manual page 94.....
Turn your scanner on and as soon as the "Welcome Screen" is showing, immediately press the 3 key.
fxdscon
¯\_(ツ)_/¯
"The BOOT code [CPU] version can be determined by holding down the PROG/PGM button while turning
the scanner on. The first line of the LCD should display: uP Boot Ver:F1.x"
Shawn
The boot code and the CPU firmware version are 2 different things. The CPU firmware version is viewed by holding down the 3 key while the welcome screen is displayed.
D
DaveNF2G
Guest
The boot code info is useful for determining which firmware loader you should use. The firmware version check is handy for making sure an update worked properly.
