Unication G5 2-tone not recording/transmitting auto
Tdubz6610
Pennsylvania
Hey all,
Looking for some insight on this issues I’ve been experiencing for a few months. The issue is when a two tone gets detected it triggers the tone like normal but then afterwards it’s just static and there’s no recording log as for some reason it’s not logging the recording.
The system that it’s monitoring is a P25 phase 2 site now I have double checked my settings on PPS and I do have the 2-tone TGID set to record. The dispatch channel is not on P25 but on an analog channel. I have spent a handful of hours trying to research the issue but can’t seem to find anyone that is having similar issues.
The firmware version of the G5 is V1.23 and PPS version 3-16-beta. I know a handful of people in my immediate area are using the same firmware version and PPS version and are not experiencing issues that I have. Does anyone have a bit of insight on what I could maybe attempt doing?
hazrat8990
Wyoming
So, all operations are analog and only tones are sent on P25? Are any tones still sent on analog? If you just scan the TG instead of trying to have it alert, how does it behave then? The only thing I can think of is to make sure you have the sub group set up correctly, and have the reset mode set to auto.
Your PPS and firmware are quite outdated, so you may need to upgrade both in order to find more help. Most folks have long since abandoned the older versions, myself included. If you only have a handful of TG's and analog channels, the transition to the latest PPS is quite painless, but will require a firmware upgrade. I can set you up with V1.35 if you choose to go that route. Whatever you do, DO NOT upgrade to any V2.0+ firmware! It is full of bugs, and wreaks havoc on older equipment.
If you don't want to mess around with upgrades, there are a few videos on YouTube that will help.
Tdubz6610
Pennsylvania
So just for reference, the county i monitor is a little backwards. So they have analog on for the dispatches on the VHF band and then everything else is then set to the digital Talk Groups. Now when i have this set to open to monitor all dispatches in the county it works fine, but when its on the Selective Call Only it'll alert when the ID match's then it just goes static with no transmission & no recording. I will go ahead and try setting it to Auto reset see if that does anything. If you wouldn't mind sending V1.35 so i can resort to that firmware version if nothing else is working.
hazrat8990
Wyoming
It should work if you change the reset mode. I will message you with the V1.35 firmware, but you will also need to use the newer PPS. Once you download and install the new PPS, you can open your current version to use as a template while building your new profile.
